Pontiac Firebird 1967-2002 - headlights make funny nosies
White94Bird
08-11-2008, 04:44 PM
My headlights make a growling noise when i let them down...
but they go down just fine and never make a nosie going up,
i was told it was gears being striped
do yall know were to get new gears??:emb:
94rt10ohio
08-11-2008, 05:40 PM
Actuator. You can actually take them apart, at least you could on the LT1s and flip the gears to get more life. I also seem to recall you can get new metal gears. Once again, this is info I am trying to recall from 4 years ago.
Sticky:
http://www.ls1tech.com/forums/showthread.php?t=177470
DevilDougWS6
08-11-2008, 06:32 PM
DO NOT TAKE YOUR MOTOR APART! I made a thread about this a while back. this doesnt work in every case but flip your lights up, remove the negative battery cable, remvoe the 10 mm nut holding the arm onto the motor, get to your adjustment knob and rotate 180 degrees from where it was before. now put it back together and it SHOULD work, provided that it was not done before and the whole gear is not stripped.
this should take you no more than 10 minutes! i have done it with BOTH of my headlight motors so far and they still work.
chemicalstylez
08-11-2008, 11:30 PM
My gear was broke when that happend... chances are the plastic gear is busted. I replaced mine with a metal one.
wabmorgan
08-12-2008, 03:15 AM
Assumeing he still sells them:
http://www.bfranker.badz28.com/headlightfix/index.htm
chemicalstylez
08-12-2008, 07:53 AM
He does... I couldn't find the link last night when I posted.
Heres a link to the video to help you out, I watched the video twice and it only took me 30 minutes. (But I also put the headlight motor in a vice for 10 minutes so the silicon would stick good).
http://www.fquick.com/videos/Install_for_Firebird_Headlight_Gear/2024
Hope this vid helps you like it helped me.
wabmorgan
08-12-2008, 12:46 PM
I had the link bookmarked.
I WISH I had put mine in a vice and waited.... It still works fine... but the housing has seperated and I have the top to a WD-40 can wedged in there to keep it in place. :lol:
I know.... I'll get back and fix it sometime soon. :lol:
BlkTransAm02
08-12-2008, 02:16 PM
Thanx guys....im glad i dont have to buy a headlight motor...
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
