99 SS vs. 99 formula
last night me and my cousin went at it, i have a STOCK 99 SS and he has a STOCK 99 formula both 6 speeds (im a better driver) we went at a roll and he beat me , shouldent the SS be faster ? if so then what is wrong with my SS , recently changed the plugs ,oil ,and tranny fluid on the SS
Yeah he might have dif gears than you do. Find out what mph he is at in 6th at like 60 and compare it to what you are at in 6th at 60. If its dif then he has dif gears than you do.
The two ways to check are to open your driver door and look on the side for the code. You could also be side by side with each other at 60 in 3rd, and see if ya'll are at the same rpm. If his RPM is higher than yours when you are both at 60 in third than he has better gearing.
