HSW Vic Jr. Direct Port
Old 08-11-2008, 05:47 PM
Mike@HSW's Avatar
Default HSW Vic Jr. Direct Port
I thought i would share a few pictures of my intake we just wrapped up. Its a two stage setup with a wet plate pulling fuel from a methanol fuel cell and a dry direct port.
higher resolution pictures can be found here.
http://www.harrisspeedworks.com/gallery/
Old 08-11-2008, 06:13 PM
DopeFedZ's Avatar
Nice! I'm having my Fast replumbed using your rails. Can't wait to get it back.
Old 08-11-2008, 08:24 PM
Cliff's Avatar
That is some really nice work. Very sweet!
Old 08-12-2008, 03:44 PM
bigdog's Avatar
can you use your interface and run two dry foggers.i mean use like two interfaces with the two dry foggers.
Old 08-12-2008, 05:49 PM
Mike@HSW's Avatar
Yes you can.
Old 08-12-2008, 07:38 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
That looks awesome! Are all of your solenoids alcohol compatable?
Old 08-12-2008, 08:36 PM
Mike@HSW's Avatar
no you would have to special order that.
Old 08-12-2008, 09:38 PM
bigdog's Avatar
why use methanol for fuel on this setup.
Old 08-12-2008, 09:51 PM
Mike@HSW's Avatar
about the same octane level as C116, quicker burn speed across the piston and a higher latent heat of vaporization which means you can run a bunch of timing because the meth burns quicker and will help pull the heat out of the combustion chamber, higher thermal energy then gasoline which yields more power.
Old 08-12-2008, 09:52 PM
02NBMFormula's Avatar
that is beutiful, pure art. thanks for the new background
Old 08-12-2008, 11:01 PM
Mike@HSW's Avatar
Thanks for the compliments guys; we put a crap load of time into this intake so it is certainly appreciated. Unlike other companies out there who claim to do intakes like this, we actually do them entirely in house, no outsourcing the plumbing, welding or anything. We take a lot of pride in all the work we do, both in function and appearance.
Old 08-13-2008, 12:41 AM
8tsixt's Avatar
Mike, Who's elbow is that? I want a victor jr but dont want to start cutting my SS hood.
Old 08-13-2008, 01:41 AM
myfast70's Avatar
WOW! Seriously guys, one of the nicest setups I've ever seen posted here!! Great job!
Old 08-13-2008, 06:42 AM
Mike@HSW's Avatar
intakeelbows.com....if you go with the gmpp intake instead of the vic you could probably clear the cowl if you dont want to cut that. that combo should probably clear the SS hood as well.
Old 08-13-2008, 12:23 PM
bigdog's Avatar
do you have any times or do you know of anyone with times or info on how to tune it.
Old 08-13-2008, 01:24 PM
Mike@HSW's Avatar
I have not run my car yet, we will have dyno results shortly. Keep an eye out, we will most likely be releasing a meth standalone kit in the near future. The real advantages are for higher horsepower cars. the price may not be practical for a street car
Old 08-13-2008, 09:51 PM
OWN3D BY MY PROF!
What sort of added cost is associated with alcohol compatable solenoids?
Old 08-13-2008, 10:28 PM
bigdog's Avatar
what is your setup
Old 08-14-2008, 07:02 AM
Mike@HSW's Avatar
it will be getting a solid roller 383
Old 08-15-2008, 06:26 AM
Zger's Avatar
I figured there was a new motor going together for this. Seemed a little over kill for the stock bottom end, heads & cam motor. The intake looks awesome though, great job.
