Need help Rearend swap now car doesn't start
I have a 2001 Z28 that came factory with a 3 channel rearend. I just did the swap to a 4 channel because it had better gears and everything went fine with the install. I didn't pull any ABS fuses and started the car up to get wheels moving to get the gear lube moving through the rearend. It made a terrible noise after it started up in park. It sounded either like the ABS going on or the sound when you put a car in park at 10mph that clicking noise. I shut the car off right away. The car has power but will not turn over at all. Not even a click. I hear the relays clicking in start mode but that is it. I even tested the starter fuse and it lights up with the ignition in start mode.
Would tampering with the ABS disable the cars starter on these cars? I thought maybe the neutral safety switch might have went out but I have no idea were it is at. I have an automatic transmission in my Z28.
Does anyone have any advice on what might have happened? I didn't think swapping out a rearend would have this effect on the car.
Any help would be greatly appreciated.
Thanks, Jim
Thanks, Jim
Other than that check your grounds, I had that problem too. All the gauges would come on but if I tried to crank it over everything would go dead and not a click from the starter.
