Max power for a Moser 12
Old 08-13-2008, 09:57 AM
Domexitium's Avatar
Default Max power for a Moser 12
Just curios on about how much power a 12bolt can take?
Old 08-13-2008, 06:25 PM
EPP
EPP's Avatar
I know they will handle 600 rwhp but they tend to get noisy. Bob
Old 08-13-2008, 07:32 PM
Domexitium's Avatar
damn, how much will a 9inch handle then?
Old 08-13-2008, 07:40 PM
EPP
EPP's Avatar
A nine inch with a backbrace is going to be able to handle just about anything you can throw at it. We're using a Moser 9 inch is this drag car, and it should be making somewhere around 2000 hp.
http://www.exoticperformanceplus.com...Car.php?car=34 Bob
Old 08-16-2008, 09:05 PM
02SOMWS6's Avatar
I have a moser with 4.30 gears and a spool. Around 600rwhp with spray. I blew the gears apart. A set of pro gears will fix this issue. A stick car is harder on the rear than a auto. If you go with a spool and a set of pro gears it will take the hard hit
Old 08-19-2008, 07:18 PM
9 Second Truck Club
stock48's Avatar
I know guy's that run 8's with GM 12 bolt's @3400LBS. 1.2X60'. Is the moser late modle F body 12 bolt weaker?
Old 08-19-2008, 07:38 PM
elanorss's Avatar
What about a moser with 3.73's?
Old 08-19-2008, 08:07 PM
jomomma's Avatar
i know mighty mouse was running a 12bolt and went like 9 flat with it. im pretty sure it will handle just about anything a street car can put out!
Old 08-20-2008, 07:16 AM
Internet Mechanic
BlackScreaminMachine's Avatar
I managed to kill a TruTrac diff wheel hopping and making 326 rwhp.....
Old 08-20-2008, 11:11 AM
01blackz28's Avatar
My freind is running 3.73s in his 12 bolt oing 9.5 with a 408 150 shot off of the line.
