New LS1 Owners - Newbie Tech - Maf Do Ya Need It
View Full Version : Maf Do Ya Need It
kevin_stamper
08-13-2008, 02:33 PM
hey guys thanks for the help on the lid question now i gott another for ya how about his aftermarket mass airflow sensors are they a fuke or are they worth the cash im gonna get my TA tuned in a while just wondering if it was a smart buy or not thanks
zracer323
08-13-2008, 05:58 PM
Don't bother. The stock one is good for up to about 500 hp. That money is better off spent elsewhere.
SOMbitch
08-13-2008, 06:48 PM
Big powa and big cubes with a 90/90 or bigger you can pick up some. Otherwise not worth it IMHO.
defenestrate
08-13-2008, 08:09 PM
put the money toward some bolts ons that will get you some power, good tires, suspension, etc.
Havok2
08-14-2008, 11:57 AM
keep the stocker.
of if you get tunned, maybe SD down the road and you get rid of it
streetassasin
08-15-2008, 06:27 AM
Ive heard nothin but problems about aftermarket maf's......save some money and port your throttle body
Tuffguy610
08-15-2008, 10:00 AM
Here's something else for you to consider when buying an aftermarket MAF: SLP and Granatelli units seem to have the same internals as a stocker with a resistor strategically placed so that your air fuel ratio will be altered so that you can "make more HP" (as they like to say). Think of those ripoff IAT sensors from ebay, $50 for a resistor that essentially dumps fuel into your car. My friend did an LS1 swap into his 87' GTA recently. When he wen to get it tuned, they said they wouldn't do it until the stock MAF was put in. This was because the aftermarket MAF (I can't remember which one, I want to say SLP) had a resistor in it that prevented the tuner from getting the best measurements (because after all, it was already altered). The stock units when in good working order are very sensitive, quality pieces of equipment. I'll also say what others above have said, put your money elsewhere. If you really want to waste money, call SLP and tell them to send you their MAF with their smooth air bellows.
SOMbitch
08-15-2008, 11:13 PM
If you are set on a bigger maf get an 85mm zo6 one or 03 up I think truck maf. Seen'em on ebay $50 or less.
davered00ss
08-17-2008, 09:19 AM
Aftermarke MAF's are junk.
WhiteFormula98
08-20-2008, 07:29 AM
what they said ^
unit213
08-20-2008, 08:37 AM
Waste of $$$. You can easily run 10's with the stock MAF.
When you start making serious power, just eliminate the MAF all together
and do a speed density tune.
mglooper
08-20-2008, 08:38 AM
and just to ask. have you had anything done besides a lid? because other wise there isnt much to be had from a tune then either. atleast not at this point...
