Little disappointed...
well I had my Datsun dyno'd at a GM show-n-shine (mobile dynojet)
No prep to the car as I wasn't expecting to make pulls but I did after some poking by my club that was there with me.
anyway
'00 LS1- 40k miles-
224/224 .567" 114+4 cam (w/supporting 918's, hardened PR's)
LS6 intake
hugger headers (only headers that will fit engine bay)
2.5" off collectors to 3" back (!cats !res)
Pulled 335RWHP and 331ft/lb and then 338/325
This car in its one track appearance ran a 12.80 @111.25
Peak HP was at arond 6500rpm
Torque was at/over 300 lb/ft from 3200RPM till almost 6k
What is my next best mod to get me some more power?
I've got about another $1200 or so that I can put into the car for this summer
anyway
'00 LS1- 40k miles-
LS6 intake
LS1Tech Premium Sponsor
Do you have the graph by chance? Between the peak dyno numbers you listed and the mph on that track run, I feel like you're missing some power with the combo you've got. Is the tune dialed in? What heads are on the engine? Any data logs to share by chance?
With $1200 you could get into a pair of the PRC Stage 2.5 5.3L heads to get a bump in compression and better airflow. We've got a sale going on them currently in the sponsor's sale section and they average about a 35-40rwhp gains on cars with similar mods to what you've got.
But let us know some of the info I asked about above. I really think there's more power left on the table with what you've got now.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
I'll scan the graph tonight and post it up. Its been tuned but most likely isn't maximizing everything thats there. I don't know of any LS1 specific tuners where I am. I will see what head castings I have when I get home. I will be doing some scanning of the car tonight with a friends laptop. I will see if I can get him to send me a copy of the data to share.
even a base tune with that cam/headers/LS6 intake should net 360RWHP+
get that car to a Professional tuner who can do a wideband tune, expect to spend $350-500 for a dyno tune.
If you don't have it already a ported stock throttle body $150 and a nice flowing airfilter
After a professional tune expect 375-395RWHP with your mods through a T56
your trap speed should go up a good bit as well.
If you put another set of heads on the car you will still need a professional tune
its an M6. it hasn't been professionally tuned yet. I guess the next step is to find someone to do a good tune on the car that is familiar with cam'd lsx's
I'll hold off on heads for now till I get this part sorted out and happy with this combo and save for a nice set of AFR's or something like that to make it really worth while.
Thanks for the input guys. Will report once I find time to get the car to the tuner.
Jason
Jason
