Need help with ls6 intake???
Old 08-14-2008, 05:06 PM
Skeet Skeet's Avatar
Default Need help with ls6 intake???
I just bought an ls6 intake off of a guy on here and he told me what to get but i cant remember what it is. I think he said it was a coolant block off line or something to that effect. I was wondering where i could buy it and what the part number is. I went to the chevy dealership today and the guy there didnt know what it was. So if any of you guys know please let me know. Thank you
Old 08-14-2008, 05:16 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
http://www.texas-speed.com/shop/item...d=242&catid=12
That's what you need. We keep them in stock!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 08-14-2008, 05:22 PM
94'BLKBRD's Avatar
You can grind the ribs down on your LS6 intake instead of wasting $50.00
Old 08-14-2008, 05:30 PM
Ok thank you. How much would it be shipped and i might need gaskets also. Thanks
Old 08-14-2008, 05:31 PM
How would you do that. I dont really no what all is involved with this install.
Old 08-14-2008, 05:32 PM
How much power do you guys think i will gain with this intake. Will i be able to feel it?
Old 08-14-2008, 05:35 PM
SSmoken's Avatar
they guy i bought my intake off of included it with the intake. Ive read where people just take a chisel and hammer to take them off or you can use a grinder.
Old 08-14-2008, 05:39 PM
Are you talking about the little cross ridges on the intake or the coolant pipes. Im assuming the ridges
Old 08-14-2008, 06:10 PM
sevenstarsfall's Avatar
Yes, the ridges on the bottom of the intake is what you will need to grind down if you do not want to buy the new coolant lines.
Old 08-14-2008, 07:52 PM
ok so if i grind them off then i dont have to buy those new lines and i could just keep those stock lines running through the valley right? or do i have to cut and crimp the stock ones?
Old 08-14-2008, 07:57 PM
94'BLKBRD's Avatar
If you grind your LS6 intake then you don't need new coolant lines or need to modify your old ones.
Old 08-14-2008, 08:32 PM
oh ok thank you guys very much. so what do most of you guys do? will it hurt the intake structure st all
Old 08-15-2008, 01:32 AM
SSmoken's Avatar
Yes what they all said. No it shouldnt hurt it.
Old 08-15-2008, 01:48 AM
Slvr00Bird's Avatar
Here's a link that will help you and show you what ribs you have to cut out if you don't want to figure it out on your own.. let us know how it goes... good luck..
https://ls1tech.com/forums/generation-iii-external-engine/618070-finally-did-ls6-intake-swap.html
Old 08-15-2008, 02:11 AM
I grinded mine down but some people dont like to and as for structure I havent had any problems or heard of any with people grinding them so you should be good to go.
Old 08-15-2008, 10:57 AM
gymratt's Avatar
I took all the ridges off with a sharp chisel and hammer. Was MUCH quicker than using a grinder, at least for me. Just take your time. My intake was brand new, I had to pause for a sec before I started chiseling away.
Old 08-19-2008, 12:53 PM
thanx for all the help guys. Im just waiting for this stupid "hurricane" to go away and then im gonna start the install
Old 08-19-2008, 07:07 PM
DarkhorSe_SS's Avatar
be very careful with the Oil Sending Unit when you remove & replace it.. Also search on the intake threads and it's recommended if you're doing the install to put some rtv sealant around the KS(s) to avoid them shortening out..
One of mine shorted out the next day since it rained and now my SES light is on.. waiting to get them shipped now and I'm out of pocket another $105
Old 08-19-2008, 09:22 PM
Ok will do but i dnt really know what the oil sending unit looks like lol. Also what is a KS(s)? I might just have my mechanic do it to be safe but i really wanna do it myself ya know what i mean
Old 08-19-2008, 09:53 PM
https://ls1tech.com/forums/showthrea...733&highlight=
here is a good pic of it... it's circled in green and KS = knock sensors.
