Iron block vs Aluminum block?
Old 08-14-2008, 08:25 PM
bigsticksupra's Avatar
Default Iron block vs Aluminum block?
In your opinion, do you think you are less likely to push water/have head gasket sealing issues, with an Iron block vs an Aluminum block? Given with the same set-up, same type of heads, gasket, and studs. I am talking about the truck block, not the LSX. Discuss, thanks.
Old 08-14-2008, 09:12 PM
OffspringZ28's Avatar
Iron is sturdier. but it really depends on the amount of nitrous used.
Old 08-14-2008, 09:24 PM
O6DODGE's Avatar
I am using a ls2 block on my build and spraying a 250 shot on it. So I will let you know what I think after I spray it a few times.
Old 08-14-2008, 09:46 PM
firefighting1101's Avatar
it all depends on the quality of parts used...with a good set of heads studs and good gaskets you shouldnt push water with either. im using an iron block, but only because it was a cheaper build that is still costing me over 12k
Old 08-14-2008, 11:02 PM
fstphx's Avatar
I hope the aluminum is OK- I have built my motor so the internals can hold 300... hope the block can I have installed a Main Girdle- not convinced it was nesissary, but it certainly wont hurt keeping things solid-
Old 08-14-2008, 11:14 PM
I am sure the bottom end will hold up in either aluminum or iron. I was wondering if the iron block in itself (since the head mates to it) would lessen the chances of pushing water/head sealing issues.
Old 08-14-2008, 11:20 PM
fstphx's Avatar
I went with the ARP studs- imo, should be fine, but intrested to see peoples experiences-
