**WTB: 99-up Fbody parts**
I am in need of a few different things off an Fbody & 5.3 truck. I would prefer stock/oem, used, and CHEAP. PM or email stephenmeredith@insightbb.com if you have them and how much you want for them shipped to 42101 (ky).
I'm just trying to get this car on the road...Thanks Guys!
- GTO dipstick & tube
- f-body tensioner (on the water pump)
- truck 5.3l 5-pin maf
- truck 5.3l front o2 sensors
- (1)coil pack from 05 or similar year 5.3
- cheap plug wires (i honestly only need one)
just to tell you so you know...you are going to have to buy a y-pipe and then either cats or cat delete pipes for the stuff that bolts to the exhaust flanges
exhaust manifolds have cats bolted to that hang down then the y pipe bolts to the cats
just wanted to let you know that since you probably didnt
no i didn't know that, so thanks. I think i'll just have someone weld up custom pipes from the manifold down & back.
cats aren't mandatory in ky (i actually don't think i've ever had them on a vehicle).
I have a idler pulley, and I think a power steering pulley and bracket probably have some used oe plug wires around and maybe misc bolts. Pm me if interested and I will see exactly what I have left
if u use stock manifolds and want to have custom downpipes made, you are going to need the 98-99 style manifolds so you can weld to them. the 2000+ manifolds are cast and the flanges that bolt up to them were part of the CAT's. if u get newer manifolds, your going to have to custom fab yourself some flanges before you can connect anything to them.
