Moving STS oil return line to pan; what fittings do I use?
When I install my new engine, I will move the STS oil return line from the passenger's side valve cover to the oil pan where it belongs. What size fittings will I need, and a part number to reference would be a bonus. I am planning to do the swap over a weekend, so time is important. I would like to have the fitting already installed in my Canton oil pan, so all I would have to do is shorten the line, install the fitting on the line, and connect to the other fitting already installed in the pan.
Thanks in advance.
Thanks in advance.
