FI LSX block machining costs?
LS1Tech Co-Founder
How much have you guys paid to machine an LSX block for FI? Just looking for general numbers, so I can compare to a fully machined ERL block.
Here is what my recent invoice looked like for my twin FI-66 build:
Bore and hone up to .120 over --- 325
Deck --- 150
Line hone main bores --- 125
fix back plug on LSX and countersink cam plate holes --- 75
Obviously most of the costs are similar to any other block prep (bore/hone/line hone/deck), but my block was an "old style" LSX block that required a little extra work to get setup. I believe the newer version addresses a couple of these issues. Also as Shawn points out below, my build did not use bushed lifter bores, orings, etc. Just a basic 6 bolt setup with standard studs.
Deck --- 150
7 Second Club
I paid $1000 for all my stuff @ the machine shop:
Bore/hone to our specs.
O-ring
Line hone
Install Cam bearings
Deck the block
Hot tank
Drill and tap for 1/2" && 3/8" head studs
Plugs for the oil galley
Balancing rotating assembly
Milling 5cc's off the pistons
Checking the clearances
O-ring
Line hone
Deck the block
Hot tank
The ERL is a nice piece for sure, all depends how much that 80lbs means to you. Once you get to a certain point with a car and need to get lighter in the front 100lbs is easily worth a couple thousand dollars.
But with the LSx block if you dont bore it out to max there is a few rebuilds there, even if you gouge it up, not sure how far you can go on an ERL or if you can easily replace the sleeves if one gets torn up.. Not to mention the priority main oiling for the LSx is a plus..
Actually the difference is more like 150 lbs.
Ive weighed an LS2 block vs a 6.0L iron block and there is almost a full 100lbs on my digital scale. The LSx block is ?50-60lbs? more than the 6.0L iron block.
My ls2 block weighed in at 87 lbs. I've seen the LQ4 blocks are usually right at 180 lbs. If the LSX is 225, that's an easy 140 lbs or so...how much is that worth to you? I think it's definitely worth it, but I'm so greedy with weight I wouldn't know where to begin.
some things that alot of people dont consider-the alum block no matter how much it is beefed up will never be as strong as the iron block,you loose ring seal due to cyl bore distortion-meaning you are loosing hp,the other thing is deck distortion,sometimes the lost hp isnt worth the weight trade off,thats why they still run iron blocks in pro stock and nascar
we have done back to back tests on iron vs alum bbc blocks,on identical 540cid bbc in the 800hp range the alum block was down 30hp and the blowby was greater.seeing how the ls block is lighter and significantly weaker than the big block+adding 20-30 lbs of boost i would think that there would be 100+ hp difference between the 2 at 1500+hp.This could be a major factor in a class that was limited by cid restrictions or turbo size restrictions.those same classes usually have to run pretty heavy so it may not be and advantage to have a lighter block.I'm not saying not to run an alum block-just trying to give all the info so somebody can make a completely informed decision for themselves-not only that,i have an alum block in my own car.
