Factory PCM and FI
Old 08-15-2008, 02:22 PM
QuickSilver's Avatar
Default Factory PCM and FI
How far will the factory PCM go with FI?
I am building a single turbo motor and want to make sure i wont be wasting my time and need to spend the $$$ on a BS3 or something.
Thanks
Old 08-15-2008, 02:50 PM
SSpdDmon's Avatar
Thanks
You'll be out of MAF after 8psi on a stock internals LS1. Unless you go with a custom OS and try to get the car running right in SD, you'll be limited to how far you can go.
Old 08-15-2008, 03:07 PM
i plan to go SD
Its not going to be a stock motor it will be either a 370" or 408" motor 6L based
Old 08-15-2008, 03:13 PM
AFASTYZFR1's Avatar
stock pcm can go a long way
Old 08-15-2008, 03:18 PM
Eurospec2's Avatar
The stock PCM, in the hands of the right tuner, is more then capable
Old 08-15-2008, 03:29 PM
Thanks just wanted to make sure guys.
