39x LTx - Year casting to use?
Is there a year LTx block thats best for that kind of bore? Do they all have the same tolerances? Starting from scratch on the block so any advice here would be great.
Does it matter if I use a block that has a .030 over bore on it already...or is it better practice to start with a stock block?
All the blocks are the same, though some came setup with 4-bolt mains. IMO if making enough power to warrant 4-bolt mains you need aftermarket caps anyway so I would not pay any extra for a 4-bolt block as it will have to be machined for the new caps anyway even if you do the straight ones like the OEM.
