300 shot spark plugs
Old 08-15-2008, 05:14 PM
BigDB's Avatar
Default 300 shot spark plugs
what plugs and heat range do I need for a 402 with 11.5-1 compression with Trick Flow heads and a 300 shot. The plug refrence chart doesnt list plugs for the Trick Flow heads for a LS1 just LT1's.
Old 08-16-2008, 12:29 AM
dnkynrbk's Avatar
you need a tr8 Its listed in the faq. as far as the part # I have ran the tr7 with a 200 shot and up to a 250 but melted one plug. Good luck and make sure you have your timing retarded. I would start at a 200 shot and work your way up. Better safe then sorry.
Old 08-16-2008, 12:31 AM
dnkynrbk's Avatar
Plug: NGK R5724-8 (stock number 7317
Old 08-16-2008, 06:38 AM
ATVracr's Avatar
I would run a NGK 10
Old 08-16-2008, 02:31 PM
ShiznityZ28's Avatar
9-10 id go 10.
Old 08-16-2008, 09:52 PM
BigDB's Avatar
arnt these non-resistor plugs? with the electronics in these cars wont a resistor plug be necessary to control RFI
Old 08-16-2008, 11:45 PM
blown69ls1's Avatar
414ci, 350 fogger, 12.1, trick flow 225's, NGK v-power #9's. Havent had good luck with 10's.
Old 08-18-2008, 08:07 AM
nahasapeemapetalon's Avatar
I wouldnt use a projected tip plug such as this from what I have heard. I just ran a big shot at the track with some non projected "tr8's" Part number r5671a-8 #4554.
I havent checked them yet but i dont think there are problems. I gapped them at .030" and rounded all the edges off.
Old 08-18-2008, 09:08 AM
gvzo6's Avatar
#4554 is a non tapered seat plug.
Old 08-18-2008, 04:45 PM
It came with washers that were tapered. It works fine on my car.
Old 08-18-2008, 05:48 PM
gvzo6's Avatar
tr8 tapered thread for ls1 b8efs#1049 per ngk tech dept
Old 08-18-2008, 07:17 PM
Do what you want, i bought the #4554 and they worked.
Old 08-18-2008, 08:38 PM
those are taperd and non projected resistor type?
Old 08-19-2008, 08:34 AM
gvzo6's Avatar
std plug,non projected ,non resistor ,with tappered seat
Old 08-19-2008, 10:01 AM
GVZO6 was correct insaying the 4554 plugs are NOT tapered, i took them out and double checked. Perfectly flat. I apologize for the arguing, you are correct.
Old 08-19-2008, 10:11 AM
Just ordered the, b8efs 1049 ngk plugs, i would advise the OP to purchase these as well. Maybe consider one heat range colder depending on your setup.
Old 08-19-2008, 10:15 AM
gvzo6's Avatar
glad i could be of some help
Old 08-19-2008, 07:38 PM
BigDB's Avatar
aight i know i need a tapered seat and a resistor plug but what about a projected vs a non-projected tip?
b8efs's are they resistor or not?
Old 08-19-2008, 11:16 PM
NO, but they work fine for people, i never had problems.
IMO, anything over 175 shot id go non projected, much less apt to blow up ground straps and cook cylinders. I shot a 250 this weekend with timing pulled, race gas, and those type of plugs, plugs looked just fine....
Old 08-20-2008, 04:47 PM
TRMIN8R's Avatar
I've been using the NGK #4554's for months now, no issues yet. Started on 175 shot and now up to a 275.
Quick Reply: 300 shot spark plugs
