Ignition switch/not starting 96 TA
Old 08-15-2008, 09:47 PM
FormulaForChrist's Avatar
Default Ignition switch/not starting 96 TA
Installed a new starter... The lil wire isn't getting any power so trying to replace the ignition switch/relay and dont know where it is in the steering column any one have a diagram? Have removed the panel with the truck button and didnt find it there and was told it is in the column and I am not sure how to remove the plastics with our breaking them :-/
Old 08-15-2008, 11:49 PM
This is pretty cool dealing with alarming the car and on the fourth step you can see the PURPLE wire that is not getting any dad gum power!
oh the link is http://www.bfranker.badz28.com/fbody/alarm96up4.htm
Old 08-18-2008, 02:38 PM
ok so you have to take 4 bolts off and 3 bolts off the 4 that hold it up with the u bar or v bar and the other 2 next to that and also the 3 bolts at the very end of the sterring wheel where it goes against the 'firewall' and then the steering wheel will drop and are able to get to the ignition switch which is on top of the sterring wheel
