Autometer wideband logging
Hey guys can anyone tell me how to get my Wideband to work with EFI live? I have the wires ran over to be able to log. I have looked under PID and no Autometer. About 10 others but not autometer. Can someone help me please?
Thanks
Thanks
Can you point me to the user manual for your specific model of wideband...?
I need to know the AFR at two different voltages...
then we make a pid for it, or if it is identical to another wideband we can use its pid.
How do you adjust the output...?
Can you set it to output the same voltage as the LC-1...?
i.e. 0V = AFR 7.35 and 5V = AFR 22.35
if you set it like that then you can use the LC-1 pid.
Hi Steve-O,
(AFR-10)/(v-0) = (17-10)/(4-0) = 1.75
(AFR-10) = (v-0)*1.75 = v*1.75 - 0
AFR = v*1.75 + 10
^ that is the equation you put into a calc pid [ if there isn't a pid already defined for that ] (pm if you need help with that).
AFR = v*1.75 + 10
