One way hose? (pics)
I am having issues finding where this hose goes on my engine. It has two one way valves in it, and it is about two feet long, give or take a couple inches.
Thanks a lot.
Thanks a lot.
That connects to the AIR Pump and to the drivers side of the Intake Manifold.
The spot where I have it blocked off is where it goes to on the manifold. The end with the blue thing closest is the end that connects to the manifold:
EDIT: I corrected myself, connects from opti to manifold.
LS1TECH Sponsor
Actually that goes to the vent on the optispark, not the air pump.
It contains a restrictor & check valve to pull air through the distributor.
There should be a second hose to supply filtered air to the opti as well. Forget these lines & you may have problems with your opti.
They all looked great believe it or not. Im actually buttoning up the car tonight so tomorrow night after the rtv has its 24hrs. to cure it will be judgement time, Im a little nervous! I suddenly got a kick in the *** to do this asap before I leave for school so it doesn't have to sit until I get back for xmas.
Good luck...Hope it works!
Don't you wish RTV would set up quicker??!!
