Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
What do you think???
Old 08-18-2008, 04:52 AM
TransAm2002's Avatar
Default What do you think???
What do you guys think about this set up???
03 Z06
Borla
Kooks 1 7/8 headers off road 3x3 X
Vararam
Textrailia clutch
100-150 shot
Added mods:
PRC LS6 Stage 2.5 CNC Ported Heads
VRX5 cam
tune
What kind of numbers am I looking at? I want to do a heads/cam and I think this would be a decent set up, but want some other opinions. Thanks.
Old 08-18-2008, 05:58 AM
Badhawk's Avatar
sounds good2me...
I'd say times anywhere from (pretty damn fast-Haulin ***)
maybe around 11.3?
Do I win?
It's hard to guess with nitrous
Old 08-18-2008, 08:45 AM
prochargedchevyi's Avatar
It looks like a good combination. The cam is moderate, but driveable; which is more important in my opinion. Nothing worse than installing an elephant cam and having it surge. That gets old really fast.
Just keep in mind, if you plan on using nitrous, try to aim for the highest compression you can. Nitrous LOVES high compression engines, and considering the PRC STG 2.5 are 64cc, I think you'll be okay. Depending on what you're looking to spend and what your goals are, it probably wouldn't hurt to have them milled a few thousandths - but at that point, you might as well build a new engine due to the flycutting you'll have to do.
Vince
Old 08-18-2008, 09:13 AM
N4cer's Avatar
What's the specs on that cam?
Mill them heads, man! Flycutting is cheap and easy... no reason not to do it.
So what traction mods are you doing? There's really no way to guess track times on an M6 car. And dyno numbers vary from one dyno to the next, even if they're the same brand. Not to mention dyno numbers are useless other than when tuning.
Old 08-18-2008, 02:54 PM
Cam is a 236/ 238 .601/.605 113LSA.
What do you all think I will dyno or MPH??? I am hitting 116-117 here in Vegas the way the car sits.
Old 08-18-2008, 06:21 PM
V-seriesTech's Avatar
It looks to me like a car that'll dyno around 430-450rwhp on motor,..and roughly 580-610rwhp on a 150 wet shot.
MPH would be roughly 125-130mph.
Tens all day if you got your driving shoes strapped tight.
Old 08-18-2008, 06:40 PM
~JOSHUA's Avatar
Just add a supercharger.
Quick Reply: What do you think???
