ms4 or what
ms4 or what
so guys im home. and looking 2 buy a cam but know very little about them. so i hear ms4 cams are the best. and have 700 $ 2 spend i need input badly dont want 2 make a stupid choice. my car is a 2000 z28 auto and it doesnt need 2 be smogged but i love driving it around all day. so help me make a good choice guys all input will be greatly apreciated. and is really needed.
I went with Thunder Racing's Reverse Split 230/224 .575/.563 111 LSA. Has a bit of a thump to it but a great daily driver and produced nice numbers on the dyno. I also went with Patriot Gold Dual Springs as well. They have the complete package with everything for right at 600.
Start with the first two links. Also the Gen III internal engine section would be a better place to get the answers you are looking for. The MS4 is a donkey dick cam that wouldn't be very friendly for daily use. JMO.
https://ls1tech.com/forums/generation-iii-internal-engine/772576-got-cam-heads-rocker-machining-questions-about-ls1-ls2-ls6-read-me-first.html
https://ls1tech.com/forums/generation-iii-internal-engine/327734-cam-guide.html
ok by not drivable what will be the problem please explain. and i apreciate u guys helping me out i really need it but really want that cam. so is there any way i can have it i dont care if im not comfertable i love performance.
Originally Posted by JD1969
The MS4 is a good cam if want to go big and not worry about PTV clearance. HOWEVER it needs a minimum 4000 rpm converter and you will need to upgrade the rod bolts as this cam needs to rev to 7000+ to get the most out of it. Also it is not the most dd friendly cam, you could go a step or so smaller and have a much more civil cam and only give up about 10is hp. Don't buy a cam for sound, get the one that matches your combo the best. BTW, you should really be asking this on LS1 tech, not a Mustang forum.
With an auto you wont be able to get a cam and related parts for it for $700 i dont think. You need first a cam and springs. You will also need a converter. Dont forget gaskets and fluids. I have a m6, so I have no idea how much they are for the LS1 f-body. If you can do all the work you will save alot, so just make sure the whole thing will fit in your budget before you start buying parts.
I used the MS3 in my 402ci and made great power with great driveability. The MS4 is way too big for a 346ci daily driver IMO. I would look into a 224R or 228R from Texas-Speed. Both have been proven to be good cams without sacrificing driveablity too much.
why cant it be a daily driver. and is there any upgrades i can do 2 make it able 2 be one thanks.
can u not be sarcastic and help me out why isnt it able 2 be on a daily driver. plus is there any mods i can do 2 make it able 2 be a daily driver. come on guys i beg 4 some serious input 4th forum were nobody will help me out. please im so serious im might get it in a week so help me thanks
