what do i need 4 full posi!
Old 08-18-2008, 10:30 PM
firehawk88's Avatar
Default what do i need 4 full posi!
Ok i left off the street today and i did the one wheelie peelie!? Im not liken it! I plan on doing a gear change from the 2.73 up to the 3.73 but what would i need to get the full posi? I'm guessing I would need a whole differential, i haven't worked with rearends much, but im going to learn. Or am i better with what i have which i believe this is limited slip right? Im driving a 02 Z28. Thanks for the help
Old 08-19-2008, 10:59 AM
Jawsgear's Avatar
Stock factory positractions are junk, If you want to upgrade and keep the same 7.5 diff I would run an Eaton Positraction.
Old 08-20-2008, 08:00 AM
badazz99ta's Avatar
+1 for eaton posi and +1 for factory posi's suckin ***
