Drag Racing Tech - tallest bias ply with out mini tubbing
ty_ty13
08-19-2008, 09:41 AM
looking at options for a et street stiff sidewall tire that will fit in with out mini tubbing.... i was hoping to be able to fit a 30" tall bias ply or at least a 29" et street in with out having to mini tub.. i dont mind hacking up the fenders a little just dont feel like doing much more... i dont need any thing wider than a 10.5" tread
what are you guys able to fit?
dlove
08-19-2008, 09:55 AM
you can fit a 30'' tire. check out the hoosier radial slick. I know a lot of guys love those. It comes in a 30x9 and a 30x10.5
ty_ty13
08-19-2008, 09:58 AM
i'd like to see some pics of a 30" tall tire fitted in a 4th gen fbody if any one has them... i know they will also grow at the far end also maybe need an extra 1.5" of clearance all the way around....
Pro Stock John
08-19-2008, 10:01 AM
Once you go over 28's, you have to cut a lot of metal and plastic, and I don't like how that looks. I think Hoosier makes a narrow 29.5 that might not require as much cutting.
You don't need more than a 28x10.5 stiff sidewall anyway, folks run low 8's with those.
dlove
08-19-2008, 10:03 AM
http://www.ls1tech.com/forums/showthread.php?t=946456&highlight=295/65
ty_ty13
08-19-2008, 10:05 AM
looking for a bracket racing tire when im not running heads up... drag radials in my past experience havent been consistant enough...
dlove
08-19-2008, 10:15 AM
search the radial slick. im pretty sure coach runs it...
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
