67 chevy II swap. i searched!
Old 08-19-2008, 10:44 AM
AMS69's Avatar
Default 67 chevy II swap. i searched!
i cannot find any info on a 67 chevyII lsx swap. i would like to know about oil pan mods,headers etc. my conversion will not be fuel injected so it should be a bit simpler as well. thanks
Old 08-19-2008, 11:35 AM
babydeuce's Avatar
There are several threads on here about C2 swaps. Are you doing a stock clip, or aftermarket?
Jack
Old 08-19-2008, 11:58 AM
rockytopper's Avatar
see if any of these guys can help
https://ls1tech.com/forums/showthrea...light=ii+chevy
https://ls1tech.com/forums/showthrea...1&highlight=67
https://ls1tech.com/forums/showthrea...4&highlight=67
https://ls1tech.com/forums/showthrea...light=chevy+ii
Old 08-19-2008, 12:14 PM
lsxlowtech's Avatar
Look at my thread, stock front end f-body and vette pans both fit.I will sell the front end and save you lots of time.Ask me any questions i will try to help in any way.
Old 08-19-2008, 12:26 PM
AMS69's Avatar
Jack
stock front
Old 08-19-2008, 02:00 PM
babydeuce's Avatar
Dont be so quick to say that the F-body/vette pans will work. If his frontend is truely stock then they will not. In order to run those pans, you must be using a front mounted rack setup, which you are. If the he still has the centerlink/tierod setup, he needs the GTO front sump pan.
OP: Comercial headers are not available for the stock clip to my knowledge. I did tons of research, and could not come up with a difinitive answer. I built my headers.
Jack
Old 08-19-2008, 02:18 PM
ssduane's Avatar
Here's my link, https://ls1tech.com/forums/showthrea...highlight=nova
Can also try http://www.stevesnovasite.com/forums...ad.php?t=58071
Old 08-19-2008, 10:58 PM
BLWN1's Avatar
details on said nova and when will it be for sale?
Old 08-19-2008, 11:55 PM
BBPanel's Avatar
I have a GTO pan for the stock clip - decided to go aftermarket front clip so its available. -Bob
Quick Reply: 67 chevy II swap. i searched!
