Fuel cut off not making sense
Old 08-19-2008, 06:35 PM
BriancWS6's Avatar
Default Fuel cut off not making sense
I have HP Tuners, but my car was tuned by a couple diff people b4 I got my own software. I just loaded my tune into the laptop over the weekend so I could adjust for the 4.30 gears. I was looking around at the file and in the fuel cut off chart it still shows the stock settings of 6200 off 6199 on My car has had the limiter set well above this for 2 yrs. Did they change it some where else?
I've raised the limiter on a buddies GTO and that's where I made the change. After seeing that, I even took my car out for a spin to verify it pulled past that, and it does.
Anybody care to shed some light on this situation?
Thanks, Brian
Old 08-19-2008, 07:05 PM
rel3rd's Avatar
Are you looking at the settings under RPM LIMITS?
Mine uses the "CUTOFF RPM vs. GEAR" ~ "NORMAL" table right below that section
You can always attach a copy of your tune to this thread and anyone familiar with HPTuners can verify.
Old 08-19-2008, 08:25 PM
ZTwentyAteU's Avatar
How much farther does it go past 6200 on your tach? Factory tach isn't that accurate. if you turn like 6800, check what ^ said
Old 08-19-2008, 08:44 PM
BriancWS6's Avatar
Ok, rel3rd, I've got it. The cutoff rpm vs gear is where it's changed. I feel like an idiot cause now that I looked at it, that's how I changed it on the GTO as well
I don't use the tach, I use a Raptor shift light, and it's set to 6700.
Thanks guys.
