BMR Torque Arm install
Old 08-20-2008, 07:58 AM
96RamAirTA's Avatar
Default BMR Torque Arm install
im about to install a BMR torque arm i was just wondering how hard it will be its none adjustable... and car is at stock height. also what are the torque specs? anybody used this setup b4??
heres a pic...
Old 08-20-2008, 08:05 AM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
Thanks for using our products. The torque spec for the torque arm bracket is 100ft lbs. If you have any questions about this please give us a call. We are in the office till 6pm est.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 08-20-2008, 10:16 AM
Undertow74's Avatar
Its Really easy, i just did My Adjustable Torque arm, PHB, and front& rear Sways this past weekend all BMR. If yours is non adjustable it will be even easier. Just a few bolts and drilling out the old mounts and puttin in the new one at the tranny. Just follow the instructions and it is an easy hour job! what takes the longest is drilling out the few rivets to put the new poly mount it.
Old 08-20-2008, 11:51 PM
96RamAirTA's Avatar
did you have to re rivet the poly mount???
Old 08-21-2008, 10:01 AM
BMR Tech2's Avatar
Hello, you don't have to re rivet it, you can use bolt and bolt it back together.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old 08-21-2008, 10:38 AM
Undertow74's Avatar
Nope, Like BMR stated just squeeze the casing back together around the busing. the bolts will hold it in place.
Old 08-21-2008, 11:38 PM
96RamAirTA's Avatar
Thanx install took about hour and half longest part was drillin out rivets. Torqued axel bolts 2 100ftlbs. Car does feel a lil differnt can't pin point how but in a good way lol.
Old 08-22-2008, 12:04 PM
BMR Tech's Avatar
Glad to hear the install went well
Old 08-23-2008, 03:21 PM
Badguy7's Avatar
Nice to hear the install went great. Im looking into getting this same product here in a couple of weeks.
Old 08-24-2008, 04:13 PM
98boxer's Avatar
squezzing the trouque arm mount bushing is going to be the toughtest part of the install, am assuming its a polying busing you'll be using? You'll really notice the differnce. My torque arm used to move at the bushing untill i put in poly bushing made a big differnce and with the ta you're adding its just going to be that much better. Just be carefull and make sure you secure the car perfectly before you get under there. You should be able to install the ta with no problems. And if you have an extra hand have them help you to tighten the ta bolts the ones in the rear, i had a tough time doing so myslef cause i had a tough time holding the wrench to the bolt and then tightening the nut, but you can do this install yourself.
