Instrument Panel Not Working (help quickly plz)
Hey guys, i recently did a m6 swap and put in a new motor. Now my guages dont work at all, they act like a ground is off but there were no ground disconnected in the int. and all the wires are attached under the dash/steering. the only thing that i couldnt find a place for was the black connector by the shifter between the two cigarette lighter connectors. it has a pink, brown, black, gray, and another color i forget. would this be causeing my probs or something else...where are the grounds and controls for the guages that i could check, also would anything under the hood cause the guages to not work?
no but its an ls6 not just an ls1 to ls1 swap. i forgot about this post, it turned out to be an engine ground though...the same ground controlled spark and the guages so it fixed both my problems.
