Wax question
Wax question
Whenever I remove wax from my car, the wax leaves little spots of wax, like tiny specs of wax that I have to buff the **** out of to get off the car. No matter how many times I flip the towel, or even what kind of wax I use, so it has to be my fault somehow.
Am I using too much wax initially?
Is it too humid?
Thanks
Is it too humid?
Thanks
Sorry for the delay, Trans Am Nationals was all weekend.
I have had this problem with both Zaino and now Meguires. I am using a cotton applicator pad, similar to the ones from Zaino. I wax in the garage, but always ideal atmospheric conditions, ie: at sunset or when humidity and temps are not perfect. There seems to be a fine line between too thick and too thin. If I try to get in on any thinner, it just streaks...
If it's been a few years, you definitely should clay bar again before you apply wax. If not, you're just waxing all of the surface contamination crap sitting on top of the paint. You're protecting the crap from leaving the paint, which is the opposite of what you want to do.
Put your hand inside a plastic bag and run it over the car. If you feel/hear any sort of grit whatsoever, it's clay bar time.
