so how hard is it to replace passenger window motor
so im not so sure if its just the motor or what.....
because its been really slow to go up...an second of all like
it goes up to a certain point an does not want to keep
going up until i leave it alone an try it again later...thats how it goes
up....so my question is...what is it??? the motor or regulator too...
an how hard is it to install......
all info would be help full thanx
Definitely the motor has gone out.
If you use the search function, I have seen a couple of good write-ups on how to change the motor. Good luck with it.
Here is one of them:
http://shbox.com/page/windowmotor1.html
its not that hard. Follow Shoebox's walkthrough, make sure you have some good drill bits, I broke a couple trying to drill the rivets out. Also, wear long sleeves and gloves when you drill the fiberglass panel out to reach the rivets. If you dont, you'll be itching for a while....
if you follow the walkthrough its cake. You have to drill holes in the fiberglass inner door to get to the window motor mounting points, then you drill the rivets out and take the motor out. The new one should come with mounting hardware instead of rivets. re-install it and thats it. The walkthrough above has diagrams showing you exactly where to drill so you dont make your inner door swiss cheese. Also if you get the Autozone one it has a lifetime warranty....
i think the regulator comes attached to the motor but I forget. And your window will go back to normal speed, and should be quiet. The autozone motor was like 80 bucks I think, I really cant remember. Its worth it to DIY, the dealership wants like 400 I think to do one.
cuz i went to autozone....he told me it was like 40 something bux an had to
order it....but idk...ima see on brands too...cuz i think i saw on some other thread
the brands a lot people recomended some brands dont member tho
