edelbrock retrofit kit
Anybody use the Edelbrock 65063 header/mounting plate kit on their 64 through 67 A body? The headers are stainless step style and appear to be less expensive than some others. I was considering using them with the BRP mount kit and H3 oil pan setup. Any comments/ideas?
I used the homemade BRP style mounts out of 3/8" steel plate stock and the edelbrock headers. I did relocate the perches on the frame so that I could get the engine exactly where I wanted it.
Don't know anything about the H3 oil pan, I used the S&P modified F-Body pan for my Chevelle.
I have done the same as 1970-Cloned.. I used a CTS-V oil pan, on my setup, it hangs about 1" below the X-Member.
My plates are 1/4" but using the Tall and Narrow Engine Mounts with modified and relocated Engine Frame Stands.
Also using the Edelbrock Swap headers, they were a great fix, no problem with anything hitting and clearence around the frame is good.
The LH8 / H3 pan is some what like all of the truck pans but not as deep in the slump. But is between 2-3" deep than an F-Body pan and 1-2" more than a CTS-V pan.
Thank you all. It sounds like the headers worked well. I have the latest version of the BRP mounts and I plan to use the 200 4R that is already in the car so it will dictate where the frame stands go once I mate it up to the motor. I don't want to fool with shortening my driveshaft. Thanks again!
