Bent push rod?
Bent push rod?
okay so ive had this problem for a little over a month.. My exhuast has been poping like no other it would put a dumdumdumdum to shame.. when i floor it it pops and misses through the entire RPM range then when i let off it pops so loud and hard that you can feel it in the seat.. now i have home made 02 exstensions witch i thought was the problem for the terrible poping and missing but my friend just brought to my attention that i could have a bent push rod and set off my knock sensor.. now i wrote this really fast without my thought so any ideas? it is a 98 LS1 with 112K long tube headers no cats and no rear 02 sensors and no tune btw
I would put money on an ignition problem. Most likely a fouled or cracked spark plug especially if the headers and/or plugs were recently put in.
Read of the problem several times on this board, most people disagree at first, can't be the new plugs, etc. A few have posted back after finding a bad plug or wire.
I'd also put money on it not being a bent pushrod, especially setting off the knock sensors.
About the 13111 O2's, read this https://ls1tech.com/forums/showthrea...ighlight=p0153
They're colder than stock apparently, most people think they are hotter, and hotter is what they're looking for.
LS1TECH & Trucks Sponsor
Is there and SES light?
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Assuming such without getting the codes pulled could keep you from finding out that there may be a code that could explain why it's acting the way it is
__________________
