CNC-Motorsports Roller rockers
Anyone ever use the 1.6 aluminum roller rockers from them. Part #0335021. Sounds like a good deal. Just seeing if there is any bad stories from them.
Are they the CAT brand? If so verify ratio and DO NOT buy SA rockers unless you want to damage the engine.
I bought 1.65s and they measured 1.6 CNC-motorsports did not care because they know they sell garbage. A friend lost a motor to the crappy SA tabs that rotate and allow the rocker to become unguided, aluminum chip quickly found bearings.
A lot to be said for "do it right do it once".
I spent like $170 on Proform 1.5s, then probably a similar amount on the CAT CNC motorsports junk, then the $265 or whatever it is for the ProMagnums, $20 on GMPP guideplates and $50 on Isky adjustables.
I bet someday I endup with shaft mounts which I could already have if you add up what I spent on all the other stuff.
The ProForm were actually pretty good, put like 40K on them and intend to put them on the wagon someday, even a friend who considers ProForm bottom of the barrel admitted they pass his inspection after 40K.
