403 and D1SC Pulley combo for 12 psi.....
I have a D1SC and was looking for a pulley combo with the SDCE set-up that would get me in the 12 psi mark, erroring on the high side, as I don't want to change it if not necessary in the immediate future and want to hit my goals right out of the gate.
I know there are lots of variables but surely someone has run similar parts as this is a fairly common build.
403, AFR 225, 9.5:1, 232/240 @ .050 115 lsa in at 0, 1 7/8 tubes, catted Y and Magnaflow rear cat back. I am also using the twin 4.5"s coolers and the FAST 90/90 set-up with the BIG air filter and stock plastic ATI hat.
I have a 7.250" crank and a 3.55 and 3.70 supercharger pulley to play with. Engine RPM will be 6300-6500 tops.
thanks
thanks
thanks
thanks
