Port and polish ls1 throttle body....
well there is a guy who does it down here in sd, but honestly i would just give it a shot and try to do it yourself. By the time you pull off your tb and then drive to a place and pay them and drive back or go somewhere to ship it you could have it done by yourself. Mine took less then an hour. I just followed this writeup.
http://www.geocities.com/wilwaxu/throttlebody.html
No Im asking about the Metal Filler. I dont know where to get that. The grinders and everything else I have.
Its much different. Technically this is just filling the Gap in the TB and making it smooth. If it was a port you would have to get a bigger butterfly valve and make the Dia. of the hole bigger.
100 bucks, thats expenise, buy the one on ebay and send yours back they give you like 40 for your throttle body. The guy is on here who sells the one's one ebay. I think his name is WS6_JAX
hey is there another link maybe i coiuld use to get to this? i wanna port n polish my stock throttle body but i wanna know the right way to do it if you could maybe tell me how to do it or maybe give me another link thatd be awesome thanks!!!
Yeah, I used a small grinder and a carbide cutting bit to take off the high spots (had to keep a pick/screwdriver around to push excess aluminum out of the threads though... there's probably a better way, but it cut through the material pretty fast), and I got one of these sandpaper bits to save a little time in the smoothing process before final sanding with high grit...
