6.0 head bolt/stud issues
Ive got an unknown year 6.0 and I need to track down head fasteners asap, the only problem is I dont know what year the block is.
I know that the newer engines used a shorter bolt with the same style heads and hte older were longer. That means I CANT use the older bolts with the newer block, but can I use the newer bolts in both the newer and older blocks?
