228/232 111, Low #s need help!
Have a 228/232 .600 .601 111
Car put down after bolt ons 318hp and 327 tq, now its at 340 and 328.
I am pretty dissapointed after doing all this work for these results. I need to start trouble shooting this problem. First, it pulls 4 degrees at timing on initial hit but 0 up top. Next, it has tr 6 plugs. I bought tr 55 gaped at 50. One the way home some serious knocking sound occured. Started as a bad exhaust leak sound to sound of metal on metal. Broke spring, or rocker possible? Valve covers come off Monday. Could loose rockers be part of my power problem? I was planning to do a compression check when I went to change plugs but never got that far
yes loose rockers will kill your hp numbers, it like running in limp mode I wouldn't suggest running it like that. I had a problem wear a rocker started to back out and caused it to missfire a hell of a lot. use some locktite on the threads it really will help. good luck hope you get it figured out. trevor
Passenger side valve cover is off, atleast one rocker arm was loose enough to be turned by hand. Im going to have everything re adjusted by this shop, hopefully everything turns out ok. If the rockers werent torqued right, could that effect power? Even though it wasnt making noise when it was on the dyno.
it may have been just starting to loosen up (which would be a ticking sound sorda like an exhaust leak but the sound would obviously be coming from the valve covers) did the shop you are taking it to the one that done the work ? if not just torque the rockers down your self. get a torque wrench and some locktite and torque them to 22-25 lbs or so. you have probably found the culprit to your problem.
Post the dyno sheet with AFR readings. Do you have a scan of the dyno run? Did you do a compression test, what about a leak down test? Is the TPS reporting 100% throttle opening? Any codes present?
Unless your race weight is 3300 lbs with you in the car, your trap speed is right on par for a 400rwhp car weighing in at 3800 lbs (with driver). To me it looks like the dyno is not reporting accurate numbers, try a different dyno. Just my thoughts. Now if your race weight truely is 3300lbs that would equate to an 11.70 @ 116 with about 400rwhp (typical cam-only numbers)
Well only thing I have out of the car as far as weight is spare tire/jack, and front sway bar which is hardly anything. I would consistantly trap 106-107 before the cam so I gained 3-4 mph. Im almost positive it has 1190s with any track prep. Motor has 93k on it.
