How much will my RPMs increase...
with 100 shot in the 1/4? Is there any calculators out there so i can get an idea? Right now i trap at 52-5300 in 4th. NA.
Thanks
Thanks
I don't think you can calculate it until you run it really since you don't know how fast you'll be going at the end of the 1/4 until you do it yourself (unless i'm reading the question wrong) if you're at 5300rpm's without spraying you shift at what, 6000 or so? You'll most likely have to shift to 5th if you spray 100 shot. That is if i am reading your question right..
Yeah, i shift at or around 59-6000 on the tac, i was told i'll most likely need to shift into 5th. on the bottle
My computer wont open that link but it did earlier and i am almost possitive its a calculator for seeing what rpm you would be at, at a certain speed, if you were to change gears in the car from 3.42's to like 4.10's you know? I think ppl misunderstood the question you had, but i'm almost possitive you'll have to shift into 5th if not you'll end up deep in the rpm's in 4th on bottle.
