Little Ram Air Scoop I Made...
Old 08-24-2008, 12:39 AM
Marc3.4V6's Avatar
Default Little Ram Air Scoop I Made...
Us LT1 guys can't use anything like the SSRA but most of the cold air kits for the lt1 are actually in a good place in my opinion. I've wanted to do something like this for a while now, tinkered around with the idea of using foglight openings but it never worked out, too many obstructions. Then I saw this:
http://www.lt1engine.com/tech/f-body-lt1-free-ram-air/
It's a little like the SSRA in some ways, a little more open then I'd like, but I did it anyway because I love, love, love doing stuff like this. I plan to utilize modify it more for use as brake cooling for when I take it road racing someday. If I have to clean the filter a bit more often, then that's fine, I don't think I want to put on one of those dust jackets which minimize airflow slightly because the whole point is to increase it by every little bit possible.
I'll take pictures of mine tomorrow. It's a little wider than the one in the link and I painted it black. Mine came out a tad lower than I wanted, or maybe it just looks that way. Anyways I don't think I'll have any scraping trouble.
Old 08-24-2008, 12:46 AM
Fixxer99TA's Avatar
Saw this awhile back and thought it was a great idea, except I still got the ram air
Glad to see someone using it, and post up some good pics I'm sure theres lots waiting to do something much like it.
AChotrod's Avatar
really i think you should have removed the plastic panel and could gain more.
Old 08-24-2008, 12:53 AM
Marc3.4V6's Avatar
What plastic panel? The pictures and link are not of my work, but how do you mean, I don't see what else could have been removed?
BTW, I meant to take during pics, but was too wrapped up in it and forgot, so you'll have to settle for pics of it already installed.
Old 08-24-2008, 12:59 AM
Fixxer99TA's Avatar
Yeah, I am actually the same way.... Once I am going theres really no stopping, someone else had better be taking the pictures
Old 08-24-2008, 01:10 AM
AChotrod's Avatar
that entire plastic panel that has the filter inside it. Cut the entire thing off and make a much bigger duct.
Old 08-24-2008, 01:35 AM
Marc3.4V6's Avatar
I basically took most of it off, but you have to keep some of it to have something to bolt the scoop to. Pics tomorrow.
Old 08-24-2008, 08:08 AM
1redta's Avatar
Default re
I took a cutoff wheel to the plastic piece and made two lines for the width of the scoop and one one connecting the front of the lines. I then took some sheet metal and bent them like a S on an angle consistent with about a 1.5~2opening. I put the S on either side of the plastic flap and used some small self tapping screws. Art
Old 08-24-2008, 09:47 AM
camar0corey's Avatar
Hmm I think the plastic there on my car has slits in it already, his looked solid before he cut it?
Old 08-24-2008, 09:53 AM
Kaltech Tuning's Avatar
Man haven't seen that mod in years.. It's worth it.. keep majority of the plastic too as to keep alot of the air going into the filter rather than just bouncing around on the wheel well...
Old 08-24-2008, 09:57 AM
Fixxer99TA's Avatar
Someone may have gotten there before you camar0corey and tried to let a little more air in.
Old 08-24-2008, 10:01 AM
Some fbody's are already vented, which are the slit's i think he's talking about...
Old 08-24-2008, 10:50 AM
Marc3.4V6's Avatar
Ok, here it is:
As you can see, I went with the bigger must be better approach.
NOTE: the scrapes where you see prmer are from the install, I didn't wait long enough for the paint to dry, and also, the metal looks a little rough because it was a piece of sheet metal I used to use as a table when mixing primer.
A few small concerns....
Even though I made it as tall as the one in the link, it appears that it's lower than the other guys, but still higher than the air dam, slightly worried about scraping. Also about rain, he says he hasn't had a problem for 6 years of having it, something still worries me there, I may make a cover for the rainy season.
Other then that, haven't felt any gains that were big enough to rule out as being psychological, but hey, it's possible, and many gains aren't felt. I had fun doing it and would do it again.
Old 08-24-2008, 10:53 AM
Marc3.4V6's Avatar
An S curve, huh? sounds cool, I'd like to see it if you can get pics.
Old 08-24-2008, 12:28 PM
Fixxer99TA's Avatar
Nice job Marc, the more air the better!
Old 08-24-2008, 02:24 PM
1redta's Avatar
Default re
not so much a curve but bends
Old 08-24-2008, 03:09 PM
slick1851's Avatar
It would be much better if you creat a sealed box around the intake with a scoop
Old 08-24-2008, 03:46 PM
AChotrod's Avatar
Looks much better than that tiny waste of time vent in the first post. Looks like you did take out most the plastic I was talking about. Nice job!
Old 08-24-2008, 04:53 PM
bricez28's Avatar
nice. a little afraid of rain tho
Old 08-24-2008, 06:07 PM
Marc3.4V6's Avatar
Thanks everyone
I think that is a good idea, I'll try and make something. That would really force all the air right into the filter and nowhere else so there would be no loss of whatever air the scoop picks up. Thanks slick, I honestly didn't think that far yet.
After thinking about it a while I realize this is going to be quite difficult. Some obstacles I see are :
-making it work while still being able to unbolt it and access the filter for annual cleaning.
-1 piece or several pieces
-a connection of ducts or a box
I'm not even sure it can be done at this point.
Quick Reply: Little Ram Air Scoop I Made...
