Best Plug Wires?
Old 08-24-2008, 02:45 PM
lt1z28camaro's Avatar
Default What wires r u running?
What kind of plug wires should I get for my car?(motor cuts out at high rpm's when it's been sitting a couple minutes and gets hotter than usual, praying it's not the opti) I saw some MSD's for $95 plus shipping, i see alot of ppl running taylors but have heard some ppl that aren't pleased with them. Recommendations?? And does the size of wire matter? I don't know much about them..
Old 08-24-2008, 05:07 PM
leadfoot4's Avatar
I recommend the Moroso Blue Max custom set. It's about $60, fits well, and I've had no problems with mine.
Old 08-25-2008, 12:44 AM
Fixxer99TA's Avatar
If the car runs fine cold and then cuts out completely (dies) when warmed up then it could potentially be your opti.
I would go with Taylors or MSD. I run Taylors and know lots with both, no problems.
Old 08-25-2008, 12:46 AM
JoeliusZ28's Avatar
had problems with MSDs and 5 times more problems with Taylors. ditched OTVC and went back to AC Delcos, never looking back.
Old 08-25-2008, 12:51 AM
[QUOTE=Fixxer99TA;9982795]If the car runs fine cold and then cuts out completely (dies) when warmed up then it could potentially be your opti.QUOTE]
The car runs fine at normal temps, but when i sit and it gets hot like it's running temp is 180-190 and if i sit in line at strip it will get up past 200 unless i turn on a/c it stays where it was at normally (makes it turn fans on or something to make it stay cool) and cuts out at the higher temps. (cuts out as in noticeable loss of power around 5k rpms) and sometimes at running temp.. i figured i need to change plugs/wires since it's a 95 with 39k on it with stock wires/plugs, i feel like that's pretty old to have same ones in the car..
Old 08-25-2008, 12:52 AM
Dave J's Avatar
I always done well with MSD
dont even think about Taylors
Old 08-25-2008, 12:54 AM
Damn, sounds like it's about hit and miss with basically all of them..
Old 08-25-2008, 01:09 AM
tspence45's Avatar
I just got some Vision Motorworks 10.2mm plug wires and NGK TR55 plugs installed on my car. So far, I'm very pleased. But, they've only been on a few days. They sell them on eBay for $60. You can get them with NGK Iridium plugs for under $100 from whatever dealer on there sells them.
Old 08-25-2008, 03:38 AM
S2K
S2K's Avatar
Location: Bristol, TN/Knoxville, TN/Mooresville, NC/Phoenix, AZ
I have MSD's on my car and have had no problems. I would recommend them. Also, I've heard good things about Jacobs Electronics; I don't know if they still make a LT1 kit though.
Old 08-25-2008, 07:18 AM
Killer SS's Avatar
magnecor wires are pretty good. i think so anyways.
Old 08-25-2008, 08:32 AM
Hot94Z28's Avatar
I have been running MSD's for about 4 years and I love them. I like them with having headers.
Old 08-25-2008, 09:26 AM
96capricemgr's Avatar
Jacob's crap was the first "mod" I bought for the car, got an ignition and wires and none of it was any good. Had a wire start leaving in just a few months and the box went bad in maybe like a year or so and I had a very hard time finding that it was the box that was the problem. Have been using Taylors and am going to try something else next time not really happy. Delcos really are under consideration too, one of those things everyone wants to throw away but is actually better than a lot of the "performance" parts.
Old 08-25-2008, 12:13 PM
lt1 hawk's Avatar
This topic gets beat to death at least once every month and a half.
Old 08-25-2008, 12:40 PM
Fixxer99TA's Avatar
True that, if a search was done I think it might blow the search option up...
Old 08-25-2008, 12:55 PM
Problem with the earch is there is more bad info than good.
Only way it is useful is if you have put enough time in to understand who writes quality posts.
Old 08-25-2008, 01:00 PM
Fixxer99TA's Avatar
Good point 96, your right about the bad info (not just here, take a look everywhere).
Old 08-25-2008, 01:45 PM
S2K
S2K's Avatar
And now I've heard bad lol. Having never used any of their products myself though, I can say nothing about them.
Quick Reply: Best Plug Wires?
