New LS1 Owners - Newbie Tech - Stock ram air baffle qustion.
2and4genbirds
08-24-2008, 08:19 PM
I'm sure this has been talked about many time and i just can't find the post :bang: about it so I'll ask anyway is it worth cutting the stock baffles out of the ws6 hood or not? i have seen here someone says cutting them out can hurt the car b/c it droppes the pressure and some says it flows more air.Or should i just let the hood factory and get one the kit that pulles air from under the front of the car? So let me know what you guys did/use on your cars and what the really deal is with both. Thanks.
Mr. Brett
08-25-2008, 12:16 PM
Not worth it.
LS1W66
08-25-2008, 02:18 PM
When I got my Hood it was already debaffled and after install I noticed Zero gains. Before the hood I had done the FRA mod and did noticed a gain from that but I do not have a WS6 raised airbox.
Whether it's worth it or not can be a bit of an argument but if you remove the baffles and seal the hood to the airbox you should see a slight gain above 100 mph.
So it's up to you
2and4genbirds
08-26-2008, 12:24 AM
Thats what im finding out that it might help over 100 but im not normaly over that and from looking at the hood it doesn't look that easy plus i'm not a big fan of having to cut up factory stuff with out a spare one to go back to if i change my mind.
RevGTO
08-27-2008, 12:36 AM
If you're concerned about keeping your car in factory stock condition, leave it alone. If you liking modding in hopes of maybe gaining something, get 'em out of there.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
