Drag Racing Tech - What to get next ?
View Full Version : What to get next ?
1320_PERFORMANCE
09-02-2003, 04:20 AM
Wassup guys, I have money to spend for my car about 700 dollars. Was wondering what mod i should do next-
*ls1 edit
*Spec stage 3
*4:10 gears
I was looking into most @ the spec stage 3 but i was thinking my car only gots 9k
I was looking into the ls1 edit cause jus put my tr224 112 lsa but my car is not giving me any problems w/cam install
Wit the 4:10, guys telling me im gona blow my rear end :confused:
So which mod would benefit me most, mods below and i race my car once a month @ the drags. thanks in advanced :cheers:
Assassin
09-02-2003, 07:55 AM
I know you had to use your warranty and I would get whatever would not void that, unless it dosent matter, if you dont have auto tap, I would get that before edit, if you get the 4.10's, and got 26" tires, they might make you spin alot more off the line, your stock rear end WILL be gone after too much abuse, with the mods you got now you should be ok, maybee you should just save up for a 12 bolt if you plan on keeping the car a long time, out of those three, I vote for the clutch first!
1320_PERFORMANCE
09-03-2003, 02:36 AM
Thanks. I got access to gm's tech 2 and some guys from this forum said i can use it with edit. How much would a 12 bolt rear end cost?Yeah i was looking @ the clutch 1st but My tech from gm said i should just wait till my clutch snaps, then changed it and told me to go for the edit.
