need pic of driver side fuel rail
I posted in your last thread, but the orientation has the square thing towards the back of the car and the long skinny tab facing downwards. However it bolts through the last two manifold bolts on the driver's side so unfortunately you may have to remove the intake manifold to rebolt it properly. It is supposed to hold (I believe) the cam position sensor.
I had this same question when doing my ls6 intake swap
"Caution: The fuel rail stop bracket must be installed onto the engine assembly. The stop bracket serves as a protective shield for the fuel rail in the event of a vehicle frontal crash. If the fuel rail stop bracket is not installed and the vehicle is involved in a frontal crash, fuel could be sprayed possibly causing a fire and personal injury from bums."
ok thanks guys... yea it will be coming off once I get the KS & harness in. I ordered the parts gmpartsdirect but they sent me a freaking exhaust tip
Now I have to wait till they respond about resending the wrong package, etc.
