NX 15# bottle
NX 15# bottle
How much does it weigh when it's filled? Will it affect the weight distribution/transfer if I relocate the bottle from the spare tire wheel well to the tunnel hump area? I'm planning on relocating the battery in it's place to remove more weight up front. What do you guys think?
33-34lbs full
I run mine in the trunk with the valve facing the drivers side. The mount makes it have a slight rake with the valve up...It works fine. Optimally, Pro teams run themstanding up. Angles up in the tire well is good, same as the trans hump...just make sure the valve is higher than the rear and the sticker is up...right?
