Code-P0443/p0440
I'm not qualified at all, but is the gas cap seated correctly?
http://www.automotiveforums.com/vbulletin/t622461.html Quick Google search yielded this result...
did you remove the purge solenoid?
possibly forgot to plug it back in.
sometimes the pins get loose in the connector itself...you can use a small pick to fix it..
if that doesnt fix it, check for continuity in the wires going to the sensor. if the connector is getting power to it, i would try swapping yours out with one of your buddies...if that doesnt work then i would suggest checking the lines for kinks or breakage..
