M9 Fill Cap/panhard issue
Old 08-25-2008, 07:19 PM
proelky's Avatar
Default M9 Fill Cap/panhard issue
My fill cap is hitting the upper panhard cross brace upon deceleration. Is it better to clearance the cap or the brace? LCA's on bottom hole, torque arm/pinion set at -2...Am I missing something?
Old 08-25-2008, 07:34 PM
EPP
EPP's Avatar
Hmm, I haven't come across that. The easiest thing to do would probably be to try to clearance the cap. Bob
Old 08-25-2008, 07:40 PM
BriancWS6's Avatar
Or, make sure the rear is centered within the wheel wells. Although I only drove mine just enough to break in the gears before the driveshaft went on the STREET, I had no issues with my BMR panhard rod and the filler cap on my M9.
Old 08-27-2008, 04:56 PM
proelky's Avatar
Thanks for the help from everyone...Bob, Moser...etc. I'm going to replace the LCA's with adjustable Spohns and it should "theoretically" fix the issue. I will post up when I get them on.
