Manual Transmission - Changing clutch. Can I just remove trans. and leave bellhousing bolted to block?
eallanboggs
08-26-2008, 03:55 AM
Got to swap concentric slave so I'm going to do the clutch assembly while the transmission is out. Can I leave the bellhousing bolted to the block and just remove the transmission proper or would I be doing myself a disservice by making this shortcut?
LS1-450
08-26-2008, 04:59 AM
The bell housing must be removed to get the flywheel out for re-surfacing. Also, my clutch assembly would not come out through the bell housing either. Don't know if any clutch assemblies are small enough. Have the flywheel/presure plate assembly balanced after re-surfacing the flywheel.
BlackScreaminMachine
08-26-2008, 05:57 AM
If it was ONLY the slave, then yes.
But while your there.... its another like 6 bolts and a little bit more wrenching. Unless the clutch was nearly brand new....
MeentSS02
08-26-2008, 07:16 AM
By the time you have the transmission out, the bellhousing is another 5 minutes away from being off.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
