Wheel sensors
Wheel sensors
i have a 99 a4 with traction control. except the fact that it doesnt work. i dont have a low track light or a ses light or track off light. i press the button and nothing happens. i pluged in hp tuners and it says its on idk someone help?
Dash light blown out? Does it come on with the key on test?
Can you spin the tires or does it push the gad pedal up when you try?
And do they spin normally after you push the button?
Why is this post titled wheel sensors?
i titled it wheel sensors because the back right wheel sensor says its not working but wouldnt that have thrown a code? i know that it lights up on the dash and the button flashes when i turn the car on but nothing happens when i press the button and i can spin them feely
Did you do any checks? The ASR/cruise control servo motor is wired and cables connected?
I had a left wheel sensor bad according to HPTuners, if I had not check the DTC's with it I would have never known, everything still worked ok.
