LS2 Alt. and W/P belt out of line
Old 08-27-2008, 12:50 PM
Jeff Smith's Avatar
Default LS2 Alt. and W/P belt out of line
I never noticed that. A guy pointed at the alternator belt is out of line from water pump pulley . I am aware of it.
I plan put ¼” space washer on top and bottom bolts of alt. where the bolts attached to it. Would be the alt. forward out little Or have to buy another alt. bracket?
Opinion? Suggestion?
Pix here>>
Add 1/4" space washer. Good Idea????
Old 08-27-2008, 04:13 PM
bczee's Avatar
Where or what brackets are you using. are the a set, Water pump the correct one for the setup.. (long/Short)?
How is the Crank pulley alignment ?
Old 08-27-2008, 05:48 PM
Jeff Smith's Avatar
I got the motor package from Wegner Motorsports.That why I am. I talked with them recently and wait and see what they response back about it.
About water pump pulley to crankcase pulley is straight line perfectly. It looks fine. Dunno about W/P short/long?
Quick Reply: LS2 Alt. and W/P belt out of line
