How annoying is a spool on the street?
I have been thinking about replacing my open carrier in my 67 camaro with a spool. I know that with a spool it will make it difficult to turn without hearing chirping from the tires. Other than the tire noise, is there anything else that is annoying about the spool?
Parallel parking is a hassle and sharp u turns are out of the question. You will notice tire scrub when turning at intersections, but all in all it isn't bad with a spool. My driving is mostly rural and I hardly ever notice I have a spool when I'm driving a car with one. Bob
Spool is no problem. I have a spool in mine and it's really no big deal. I also had a Detroit locker at one time and I can tell you it was dangerous with a 6 speed in rainy weather. Just a for what its worth, a spool is much more driver friendly vs a locker.
LS1Tech Premium Sponsor
if you run soft compound tires (i.e. drag-radial, ET Street, slicks) the tires will not make any noise or chirps when turning. a standard hard compound street tire will make noise, though. parking lot maneuvers, backing out of your driveway onto the street... things like that will be where you feel the spool. other than that... for the cost and the strength factor they really aren't bad at all.
Spools work great although I just removed mine and went back to an Eaton center section. Think of a spool as both wheels are always driving forward so even in turns the rear tires will always point you straight. It feels like a push all the time. They work great for drag racing but Dukes of Hazard powerslides out of turns won't happen.
And spools in wet weather are suicidal
