Wideband Questions
Wideband Questions
Ok I have been reading about hooking up a wideband for logging with hp tuners threw the a/c pressure or threw the egr. First I have heard that with logging threw the a/c I will need to turn a/c off while logging. If that is the case, can I unhook my a/c pressure and just hook the wideband into it and use it to log while still retaining a/c? My car still has egr, so if I go to log threw that what problems could I encounter? Also I do not have aftermarket headers and am soon going to be force inducted, will it make a difference if the wideband is on the left or right side before the cat or not? Also the wideband is the lc-1 if that helps any.
Seriously help a guy out here?
If he hooks his wideband up to A/C pressure line or EGR will there be any bad things because of it?
Aka a/c won't work or what not?
Need to know before tomorrow when he installs it.
Also put the sensor on the left or right exhaust bank?
Thanks in advance!
Thanks in advance!
You don't need to turn any codes off. You connect the wideband to the Brown wire (I think) for the egr valve and that sends a 5v reference signal to the pcm so you can see your wideband in the scanner. I have the NGK so thats how mine is connected, your may by a bit different.
Try this: http://www.hptuners.com/forum/showth...light=lc-1+egr
Thanks for the help we appreciate it!
So to make sure where crystal if you cut off the egr line and replace it with the lc-1 wideband signal there will be no ill effects on the car besides the check engine light for the error codes? No changes in how the car runs or a "limp mode"?
Again thanks!
Again thanks!
