Turbo Question
Old 08-28-2008, 03:43 PM
2000ramairformula's Avatar
Default Turbo Question
Im thinking of building my own rear mount turbo kit. Pieceing it together, piece by piece. What size turbo and exhaust housing will I need on a single turbo? I know that I will need like 42lb. injectors bigger fuelpump but do I need a different mass air? Just some questions that I had and any good input would help.
Old 08-28-2008, 03:55 PM
67Firebird455's Avatar
I built my own, worked out okay, and saved a ton of money. I got a master power T70 turbo, check out modularturbo (newer sponsor), he backs the products, and is friendly. Ford motorsports 42lb injectors, can't beat them for the price, and they'll support mid 450hp. Same mass air sensor, just obviously a good tune. My turbo had a .68AR on the hot, .70AR on the cold. You'll also need something like a mocal pump to scavenge the oil out of the turbo since it'll be mounted below the pan.
Old 08-28-2008, 04:00 PM
Don't mean to be noisy but how much did you end up in that? This person modularturbo, can I just do a search to find him.
Old 08-28-2008, 04:08 PM
$3500 total with fuel system, injectors, turbo, intercooler, turbosmart blow off valve and wastegate.
Here's his website... Think you can find him with a search...
http://modularturbo.startlogic.com/c...8408c12ea5de06
Old 08-28-2008, 04:13 PM
thanks, was this the same place you got the wastegate and bov?
Old 08-28-2008, 04:15 PM
I actually got the BOV from ebay, the wastegate from Jose @ forced inductions (sponsor here, contact Dr Turbo if you prefer). Turbo was ebay too since it was used.
Old 08-28-2008, 04:31 PM
thanks for the info
Old 09-09-2008, 04:52 AM
ModularTurbo's Avatar
I would be glad to help, just gimme a call 252-562-3899.
Old 09-09-2008, 07:10 AM
Silver_TransAm's Avatar
Check with Rob at modularturbo, he is a good guy and will go the extra mile for anything you need.
Rob, that t76 is great! lovin it!
